I haven't been on in awhile, but I have another thread where I was going to do the same swap to a standard Mazda3 Hatch. Plans have changed. I got my Son's first car back recently. For those who don't remember my other build thread I had started is called "2005 Mazda 3 Hatchback gets DISI" I was going to do this to my Son's Mazda 3 Hatch, but recently, I acquired his first car back. I already have a 2007 Speed3 GT, so I really don't need another Speed3. But it was my Son's so I will still keep the 3 Hatch body for future project, or incase my Speed gets totaled I will have a complete straight body to swap everything over to. If you want more info, just find my other thread and check it out. But, that thread is on hold unless this swap WILL NOT work.
I have a complete running 2009 Speed3 Sport totaled due to body damage. I bought it back from insurance. It runs/drives like it did before accident. Steering wheel isn't even off center. I got my Son's first car back. He died back in July 2015 at 24 years old. So, I'm happy I have all 3 of his cars now. His first car was a 2000 Mazda Protege lx 1.6L. 2nd car was a 1970 Datsun 510. His 3rd car was the 2005 Mazda 3 Hatch that I originally was going to do the swap on. I ended up with Thyroid Cancer, so I have been dealing with that so nothing has gotten done.
I am now ready to strip the Protege down, and start building a full Mazdaspeed 3 swapped Protege. I have been crawling over, under, measuring everything. I am surprised the engine compartment is same size as Speed. Wheelbase is 1.1" shorter on the Protege, but I could easily mount subframe back an inch to make it the same length as Speed. The rear subframe looks to be no problem to mount to frame rail. Will need to mount the trailing arm, but Protege uses one also. Almost mounts in same location so it won't be that hard to fab up a trailing arm mounting location. Rear of front subframe mounts to the original Protege subframe location. Front mounts 3" more forward, but is easily doable. The Speed dash will physically fit into Protege. Protege is actually about 1/2" wider inside than Speed in most areas. I will swap complete dash, steering colum, pedals, console, shifter, etc... I will use Speed seats, and mount the rear side curtain air bag modules over rear doors like in Speed. They almost bolt right up. Basically I will be using all external lighting, trunk light, dome light, power windows/locks, wiper motor/linkage, carpet, and headliner. All else will be removed.
I will take some pics tomorrow.
Any thoughts, questions, ideas, let me know.
I am going to fully document this build all the way through building, to having it inspected by California B.A.R. and getting swap legally certified. Rule in CA is that engine has to be same year or newer, and same size or larger, with all emission components installed off of motor being swapped in.
