Total Noob Seeking Tune Help
Dougie F
2008 MS3, HPFP upgrade, COBB intake and downpipe, Stock turbo went bad, Installed; CS CST5 turbo, 4" intake, EBCS, 3.5bar MAP, Garrett FMIC. fired car up, no idle. changed MAF 1&2 calibration tables for 4" intake found in this form, able to idle, will not rev up past 2000 rpm. Also DTC's P0101 and P0234 stored. Using Versatuner. Any help is greatly appreciated!
https://mazdaspeeds.org/index.php?threads/versatune-big-turbo-basemap.4533/
A good place to start. I do hope you have the Versatuner full version because you must have it to do all the tables that will need to changed. And spend many hours researching here and everywhere to get up to speed.
Definitely better in long run to get it professionally done.
Be very careful with the modifications and stock rods.
