TPMS Sensor Receiver Issue
Worbit
Gold Member
So my TPMS light is still on even after swapping out all four sensors. At this point I’m guessing it’s the receiver that is the issue and I was hoping someone would be able to tell me where it’s located in the GenJuan.
If you have a USB charger plugged into the accessory port, remove it. Drive it a while and see. The USB chargers can emit a signal that disrupts communication between the sensor and the module.
Yeah, air is in the tires and we can read each sensor with the scan tool. When I put in the OBDII reader it says it can only read two sensors and has an error code of B2143
