Hi guys. My 2006 mazdaspeed6 is running like crap. I have a U0100 and also a lean at idle code. Everytime I go from 0 throttle and then try to accelerate, my AFRs jump, the car stutters and sometimes backfires/misfires for about 3 seconds and then the AFRs drop back to normal and the car takes off. This happens at first start from idle as well as after every gear change. If I power shift it basically eliminates this issue. What I am trying to do right now is a boost leak test. I uploaded two pictures. One is showing my setup. I have the boost leak tester hooked up at the air inlet where the filter usually goes. I have the two lines bent over and pinched that are also attached to that inlet. I have air coming out of the open pipe at the valve cover shown in that same picture. The other picture shows where air comes out of if I block that open pipe. Because air comes out of either location depending on how I configure it, I cannot listen for air leaks. The pressure I am using is between 5 and 8 psi. I'm not sure exactly how to do this boost leak test or maybe I'm doing it right and there is some problem letting air leak by somewhere. I've watched videos and searched forums but so far have not found any solution. Sorry for the long post.
