Maybe someone has some idea where these go. Car currently won't start. Will crank fire and die immediately. I'm wondering if any of these have something to do with it.
1st pic with the ground wire is coming off the coil pack/injector harness. Post coil pack wires, but pre the plug for injector wires.
2nd pic with the purple wire come out of the harness just before the map sensor.
3rd pic with the 2 blue wires come out of the same harness as the purple and look like they trace back to around the power steering pump and then disappear into the harness. I don't believe these are factory.
4th pic is a plug and wire that to the top of the picture is not connected to anything. To the bottom of the pic it looks like it connects to the ac compressor.
Thanks
Sent from my SM-G975U using Tapatalk
Thanks
