TheCopyCat
I've got the valve cover off doing a VVT replacement job and anything else I find while I'm in there. I measured valve clearances, as found below (170k miles) I built this spreadsheet myself using the shop manual. All of the current are missing because I haven't taken off the camshafts yet.
I have not taken the camshafts off yet because I was not sure if this is something I should definitely do with these readings. They are out of spec, but not far. I think I am going to do the adjustment and buy new buckets, but I wanted input from anyone here with more experience. They are almost all out of spec, and I do have some valve noise. Attached is a video of idling just before I started work.
Anyone have any thoughts it would be appreciated. Also looking for suggestions on where to purchase the new ones online. Thanks in Advance.
Also for anyone curious here is the spreadsheet.
docs.google.com/spreadsheets/d/1fDd8Dxb9sdT4XwLlR1QkYT5lJGY9dK6-6Q5UiE_Zlvo/edit?usp=sharing
