I have thoughts that live rent free in my brain and idle mind times lead to crazy thoughts. I will preface with how this fits within my goals and would like to figure this out or put a nail in the coffin...
I am building my car to remain closest to the original package Mazda created and not in search of max power or building for the track. A Mazdaspeed6 with the more power like I think Mazda would have built it is the goal. I would like to have it look sleeper/stock as possible. To do this I use black options, not flashy colours/chome, I keep plastic panels and shields in place as much as possible.
A CST4 is the next item I need to purchase to be able to make it to 400hp using WMI. However the idea of purchasing a CST5 so that I can build a bottom end and add PI later to reach the ultimate of 500hp is real hard to forget. If I could make this work, I will be able to still check a few boxes...
What is the consensus on why PI cant be run with a TMIC?
My initial thoughts were related to the space available under the top mount. So I measured the space between my OEM TMIC and the top of the OEM manifold where it meets the head...78/82mm on each side. With injectors as short as 34mm, there is 44mm of room to fit a fuel rail and have some air space. Still maybe too tight. I came across this photo in Corksports 8th port kit (here)...
However, In the description Corksport also states FMIC only. If you subscribe to conspiracy theories, continue reading, lol.
***I just re-read thru the CS page and I dont see anything about the 8th port kit not working with TMIC***
Initially the only way to add port injectors was to use a spacer plate. This would change the distance of the intake manifold from the head and therefore change the location of the front mounting points for a TMIC. 2 options only remain to keep the TMIC mounting points in the OEM location. Machine injector port provisions into the stock manifold or use Corksports intake with port option. Im guessing the OEM manifold might need to be single runner modified to make it work. I suppose the amount of heat around the injectors and rail could be a issue. Not sure how to deal with that or if its even a problem. Could be costly too if that lead to a leak of fuel
Another idea I had involved these ports on the CS manifold where the large chamber meets the runners...
Fuel could be injected here. Im no automotive engineer, is that going to cause problems?
Im also curious about the underside of the OEM manifold, if there would be room to slide a rail in there somehow...seem like a hail mary throw at an already crazy idea tho.
Based on Corksports FPR pic, Id like to see what I could dig up to make that work. Initially, the symposer(?) would need to be relocated, but thats easy enough. Anyone have any interesting thoughts or areas I need to consider?
- Ditching WMI...its not its all cracked up to be.
- Keeping stock flange turbo
- Keeping TMIC and shroud
- Keeping EGR and stock manifold junk
- Keeping the backside of the valves clean
