Wiggles front windows - MS3
Speedhunter
My two fronts windows wiggles when I push down and up ... and the windows come hit the frame of the door ... I remove all the door panel to go tighten the 2 bolts in plastic arm ... but it's doing nothing on the wiggle ... I can move it by hand (front and rear to create the problem) ...
Do you have any idea what I could do to avoid this ?
Thanks for your help
Yeah the guides are either worn or broken.
is it the part I need :
OE Replacement Mazda Mazda3 Front Driver Side Door Glass Regulator (Partslink Number MA1350108)
[doublepost=1503281568][/doublepost]
I have this same issue starting to happen, unfortunately the only fix is new window guides.
I believe you need the tracks on the sides. What the window rides in not the reg itself
My driver side window does this as well, I will likely do a real fix on it eventually and report results.
