Hey everyone, I've just recently installed the SP63 6th port aux fuel injection kit into the car. Started tuning and so far so good with no fuel leaks, good low side fuel pressure, and nice cool bat's (mixing 2 gallons of in tank meth).
I decided to install a fuel pressure gauge, oil pressure gauge, and most notably an AEM AFR failsafe gauge. I've also installed an N2MB WOT box to prevent a lean burn during Flat Foot Shifts, and when hitting the rev limiter.
Since the aux fuel system will keep spraying during these two occurences, a dangerous lean burn is possible since the oem rev limiter and FFS feature will cut the stock injectors, and not ignition like the WOT Box does. (Thanks Nishan)
The problem I'm having is that the AEM AFR failsafe is triggering my Guardian angel during a WOT box FFS. I noticed in my logs that there is usually one cell that displays lean to about 29:1 during a FFS, but I'm assuming this is because the oxygen is detected by the wideband sensors, since it's not being used in combustion when the WOT box cuts the ignition.
Since I have my WOT box ignition cut set to 250 ms, I tried setting the AEM failsafe trigger delay to 300 ms, but the Guardian Angel still gets triggered by the AEM failsafe during a FFS, and causes boost not to return into the next gear.
Is it possible that I need to set the delay on the AEM failsafe even longer?
Thanks!
Thanks!
