Marco Medina
Hey all, I was hoping someone here could help me out with an issue I'm having and maybe someone else has experienced the same.
I have a 1st gen speed 3 with a built motor, Port injection with a AEM 340 fuel pump and ID1050s, ST manifold, CPE exhaust manifold, BNR S6, CS 4" intake, CS 3.5 turbo back, TR1045 IC, 3 port ebcs, and currently on my 5th revision on 30psi on pump 93.
During my 3rd to 4th gear shift I'm losing fuel pressure while doing a pull. It's weird because my AFR doesn't go lean but the car sputters and drops down to around 1200psi for a few seconds then jumps back up for the rest of the pull. I'll post a log for you guys to check out but I'm lost at this point because the only time it's dropping pressure like that is right after a shift into the gear while racing. Not sure if maybe the Split second controller map needs adjusting or the tune itself or if I have something else going on. Datalog 7 is the 3rd-4th gear log and datalog 8 is a WOT log in 4th
