2013 Mazdaspeed 3
158000
Chicago IL
Occasional stumble/breakup at WOT
Built motor. BNR S3. PD tuned and all supporting mods
New OEM coil packs within the past 1000 miles.
So I have had a cylinder 1 misfire code twice now, plugs only have about 2500 miles on them so I decided lets just replace all my coil packs since they were original and if one is going they probably all will sooner than later. Same code returned a couple hundred miles later. Car pulled hard and I couldn't feel anything out of the ordinary when the CEL triggered.
At this point I decided to put a brand new spark plug gapped to .026 in cylinder 1 as well as swap #1 and #4 coil packs even though they are brand new. I also did a compression test to see if anything was abnormal with cylinder one. Compression shows 175psi on that cylinder. I did recently put a different wiring harness on the car over the winter that I stripped down and rewrapped to make it look nicer. I didn't see anything abnormal about any of the wiring but it is worth noting I didn't have any of these issues on the original harness but that may just be coincidence.
I was able to capture a data log of this behavior and its attached. I'm far from an expert at reading data logs and using the info to troubleshoot but what did stand out to me is the fact my IDC is showing well over 100 percent, maxing out at 120. I could feel a misfire/stumble on this log but it did not feel like the abrupt fuel cut that I've experienced with a boost leak. What is that IDC indicative of?
I have 4 brand new OEM injectors and was planning to get some new Overspeed or CS seals.
HPFP is a new Hitachi unit also new CS internals under warranty and the PRV was replaced with an OEM all with in the past 1500 miles.
@Enki and anyone else that can help!
158000
Chicago IL
