just purchased this 06 MS6, silver, with white/black leather interior and navigation. (no sunroof though, dont know how thats possible)
Is that chp or whp? The fmic is already here, so it'll go on. Turbo is for sure getting replaced. Just a question of which turbo. Precision 5858, BNRS3/ or BNRS4. I'd like to be around 400 whp. But if I get to 375-380 on pump I'll call it evenI would throw the CorkSport turbo in the mix. With tmic I hit 386HP 357TQ and still tuning. That was with E-30 and 91
Dyno jet numbers. Speed3 that had same set up but with front mount and fully tuned 425WHP with 4-8 E-85.Is that chp or whp? The fmic is already here, so it'll go on. Turbo is for sure getting replaced. Just a question of which turbo. Precision 5858, BNRS3/ or BNRS4. I'd like to be around 400 whp. But if I get to 375-380 on pump I'll call it even
just the stock (albeit fairly uncommon) black/white leather interior. whats really rare is theres no tears or stretches in the leather at all.Unique interior. It's not that bad looking.
I plan on doing full mounts. I have seen pics of our stock rear diff mount broken in half. Dredd Jugg is good. Turbine Tech has one that pairs with the CP-E rear mount.should i do rear diff mount bushings? or full mount replacements with something like the dredd and jugg?
im just not looking forward to doing them. the process seems intensive, but not complicated. just alot of unbolting and moving shit.I plan on doing full mounts. I have seen pics of our stock rear diff mount broken in half. Dredd Jugg is good. Turbine Tech has one that pairs with the CP-E rear mount.
looks amazing and stock at that. did you have to modifiy that lower grille? if i remember correctly the top half of the grille is covered on the backside which would prevent airflow from reaching the FMIC.I found the front mount overall, fairly straight forward. Took one day and a little cutting. Now looks like it was meant to be there. Now its much easier to get to things on top and Bats are 30+ degrees cooler.
