Within the last 2-3 months I have noticed an intermittent stumble while driving that seems to be getting worse, and I think accompanied by a sulfury smell from my exhaust....
Check out the logs I've posted, I think my AFR is f**ked and that is throwing everything else out of whack because I have a bad O2 sensor or a totally clogged cat.
Driving was semi-normal today, then a large bunch of stumbles around 550s to 590s mark where you can see lots of things go haywire, I'm just not sure what went haywire FIRST and caused trouble everywhere else.
If that is the issue I'll probably go full high flow cat exhaust from edge, just hoping for a few opinions before I squeeze the trigger on it.
logs are attached! also a screenshot from that same timeframe as a little visual...labels are on the left except for:
red = absolute load
light orange = accelerator pedal position
dark orange = wastegate control solenoid duty cycle
red = absolute load
