1st Log
PapaBone
2 Car seats = +100 hp
*Mods move to noob area if this is in the wrong place
Hi Folks,
So I had a random CEL this morning, P0455 (turns out to be gas cap related in most cases) but thats beside the point.
I ended up taking my first log before I researched further what the problem was. Anyways, would you guys mind taking a look at my log (3rd gear pull from 3k)
Mods:
Cobb SRI
Tune:
Cobb Stage 1+SF With Modification ao Load A and C tables here : http://www.mazdaspeedforums.org/forum/f418/fixing-jerky-throttle-response-atr-26456/
The only thing I know to look at is HPFP, and that seems to be in the good. Anything else jump out at anyone - I see the KR .035 at a couple spots...
Thanks All
the only thing i notice is late WOT. Add the Actual throttle position to you logging tables. Then get another log and go WOT around 3k
Log looks fine. I know it's high speed but a fourth gear WOT from 3000 to 6500 will be more telling any day than a 3rd WOT.
Thanks for the review guys, yeah 4th gear pull is very fast. I might have to find a secret spot to do it though.
It was my first log ever so I was timid anyways, I'll get better at it. It is soo nice to see how the car is operating via a log. I just need to familiarize myself with some of the values good vs. bad.
Knock is the most important thing to monitor IMO. If you see that number above 2 at WOT you should back off and investigate. Optimally you want 0 knock but if you occasionally see that number hitting 0-1.6 your ECU will take care of it.
