So, I'm working on @Chef's car right now that keeps running lean at low RPM's and rich at high RPM's. I have attached two maps below which are the most recent revisions. I've attached a pair of trimmed WOT logs for each one (in a single file), one of which I took the liberty of graphing so you can see the especially puzzling response in the top end.
The only difference between these two maps is that in the second map labeled "5", I:
Information on the vehicle:
Gonna tag some speed6 people here, who are already tired of me PM'ing them and complaining about this car.
@phate @nindoja
- Changed the AFR target from 11.5 to 11.0 (to rule out "table hopping")
- Used the calculated AFR/target ratio at each MAF voltage to correct the MAF curve
- 2006 Mazdaspeed6 with generic bolt-on modifications, boost-leak tested recently @ 25 psi
- CP-E "nano" intake
- K04
- E33 E85 mix
- Most tables are at the Cobb OTS Stage 3 values, except the fuel pressure ones (I use the Stage 1 tables for those)
@phate @nindoja
