darrian
Hey everyone help me out here.
I have a 2009 gen 1 wis 161k miles
Just yesterday on my lunch brake my car ended up throwing cell code PO302 (misfire cyl 2 detected) after it got raspy and poppy sounding at 2k rpm and 30 mph I was in town when this happened.
I drove my car home by babying it never over 3k and it drove fine.
Today I dug it out figured I’d start small(least problematic)
1. I Unplugged coil packs- every one unplugged made the car run ruff at idle. Thus meaning they all working like there supposed to.
2. Spark plug- I pulled them and confirmed all the spark plugs where working number 2 was covered in sut and oil. Every other cyl had oil just lightly(blowby I assume) number 2 was wet almost tho and showed oil build up in the piston all of them had oil on them tho but none like number 2 spark plug tho so I put a new set in no difference, NGK NITRUIM
3. Compression test- now I read numbers are 140+
My car was cranking with all covers off each cyl in order from the belt 1-(105) 2-(110) 3-(105) 4-(115)
Which generally means it’s running fine as long as there all in a range of each other
Combustion happens at 85psi
I bought fuel cleaner and booster for injectors 30 ounces for 3 gall and put it in my tank
It stopped the misfire at idle and driving I can now get up to my launch control (4500) no misfire
Idle don’t misfire
Driving no misfire all the way until 4k (shift)
my cars only misfiring under boost load now don’t matter if it’s 2k rpm or 6k boost load
If I stay (00.00-(-10.00) no misfire if I go positive on boost load my car starts shuddering/ popping and stuttering. I’m genuinely lost on what would be causing it did a injector lay down?
I dont care how much the fix is I’ll buy a turn ready motor have to be im just trying to find answers before I bite the bulllet
Could a injector laid down al
I was just casually driving when this happened.
This is the only code my car throws, sometimes it throws rich at idle (clear it)
Build sheet
It is tuned Cobb access port
On 91 oct and 15pounds (daily)
On 93 it makes 21
Cs downpipe
Cs manifold
3inch exuast all the way back full delete
High pressure file pump
Cs cold air intake
Cs blow off
Internally I believe everything is still stock
It’s just fbo and tuned help I’m confused
Idle don’t misfire
Build sheet
On 93 it makes 21
Cs downpipe
Cs manifold
Cs cold air intake
Cs blow off
