[SOLVED] 2010 Mazdaspeed3 ign coil packs?!?!
captaingeoff
I'm looking all over for non-oem coil packs for my gen 2 MS3. Can only find for regular mazda 3. Nopal? Accel? Weaponx? Do these all fit gen2, as well? Car has slight miss under different loads, speeds, throttle, acceleration. Sometimes very apparent to any car guy in car, sometimes subtle enough only I feel it as driver. Running one step colder NGK, gapped per factory spec (can't remember, .026?), all else stock. 83k miles. Have done crank posit sensor, camshaft posit sensor. There has not been a single soft or hard trouble code or CEL, at all!!! Wtf?!?!
If stock, I would run stock heat range, and .028 for the gap.
Additionally, you could try stretching the coils, and check for shitty connections.
Sent from my Pixel using Tapatalk
I'll probably go back to stuck plugs, stretched springs already when I installed the cam and crank pos sensors. With a gap that wide, risk of blowout?
