2010 MS3 Idling rough, Doesn't make vacuum
Vince Scatena
Year/Make/Model: 2010 Mazdaspeed 3
Mileage: 140k
Concern: Barely idles, Doesn't make vacuum, No CEL, Doesn't smoke, I did find corrosion on ecu wondering is that is my only problem.
DTC's: None
Modifications: Freshly built motor, BNR s4, Corksport HPFP, Deashworks In-tank pump, 3in intake, Catless DP, Full straight pipe
ECU/Tuning Software: COBB
Tuner: Me
Recent Repairs: Motor is Fresh have about 300miles on it, All new VVT, New Injectors, I've tested cam and crank position sensors, Mechanical Timing is Good, Grounds are good, Exhaust isn't plugged,
Correction:
I've Attached a datalog and pictures of the ECU
Sounds like a leak, ground issue or throttle body isn't connected to harness or poor connection to MAF. Dirty MAF also never helps
I checked for vacuum leaks, didn’t have any. I also tested the booster. And cleaned the MAF. Didn’t see a change.
It has to be either a leak or a bad maf
Check the wiring, check the connector and check that it's not installed backwards first
You need to inspect all of the wires coming from the maf
