PEWP3W
So back in October of 2015 a friend of mine worked for a dealership who took in 2010 speed 3, with 60k miles. The car had the FMIC W/ Ram Air Kit from Corksport(CS), a CS turbo back exhaust, HKS SSQV4, CS passenger mount, an upgraded clutch (still have no idea what, all I know is it is very heavy) and some bs tune that had 2-step setup at 2,900 rpms, car was 100% VTA. I had drove stick for the equivalent of maybe 5 miles before purchasing this car, and I stalled it a few times going home.
After getting in touch with some local people, I decided what I needed for the car and so purchasing began.
BNR S4
HTP 3.5" Intake
CS 3.5 bar map sensor
JBR 3 port EBCS
JBR 88-duro RMM
JBR 80-duro PMM
NGK step-colder plugs
Damond EGR delete
V2 Accessport
Autotech HPFP Internals
I started the installation process on a Wednesday night and finished Thursday night, done all in the driveway without taking the manifold off of the car with a few friends. Here is the route to take it out without removing the manifold.
Here is the comparison between the two
And here is the finished product.
Now came the fun part of tuning. We (Mark Gibson) breezed through the 93 octane version of the logging in about 2 weeks worth of time. Then we began to run a 3:1, 93:e85 mix, which came out to e29 right about. Holy shit. E85 is a gift from the gods no doubt. You will see below the difference in my vdyno of 93 v e85 and it is absolutely amazing. Now we could have pushed the 93 harder, but because I am going to be running my e85 mix all of the time, there was no reason to push it.
Here we have the unofficial results of my final vdyno. I say unofficial because Mark will be sending me his vdyno based on my final log though I believe this should be pretty close. My CF is what Mark had set it at, and we used it because it was pretty close to a local dyno. The WT we just determined with me in the car was close to 3500. For anyone who will knit pick either of those 2 variables please see the door. The point of this representation is to show the the curve and difference of the fuel types not the peak numbers. The curves mean more to me than the peak numbers.
I do not have a 1/4 mile time yet, however this Sunday (24th) I will be at IFO in Columbus, Ohio and it will be my first time on the track EVER. I have low expectations honestly, I am just hoping to run in the 13s though I know without slicks I will have lots of spin. This next year I will be working on my driver mod a ton. My 60-100 time using 3 of my most recent e85 logs is right about 5.6 seconds.
So for the future I have some work cut out for me. Unfortunately that small FMIC that comes with the CS Ram Air kit, is not keeping my BATS down. We are starting to see 40-50 over ambient temps. So that plus running out of headroom on fuel, we have to stop here for now. The car feels great and this will hold me over for now. My future builds will come in waves mainly consisting of 3 waves.
Wave 1: Tying up loose ends, to ensure the car can stay at its current power safely.
JBR Trans Mount
Bigger FMIC (thinking TR1035)
Dual OCC setup (using my already bought perm plate)
Wave 2: Stiffening + Better Grip, because the stock 18" are expensive to buy tires for... (Maybe aestethics)
17"x9" Wheels
255/40/17 Tires (unsure about brand yet)
ISC Coilovers
SPC Rear Camber Arms
MAYBE ON THESE LAST TWO (haven't really made up my mind yet)
Strut Tower Brace
2 point Under Brace
Wave 3: Bottom end + Head + MOAR FUEL + Meth + and other various parts
Too many parts to list, however I think it should be known I think I will be going with a relentless ported and polished intake manifold for meth, and going 6th port for fueling. BNR CLAIMS this turbo is close to 500whp capable and I am going to find out.
If you have made it this far then all I have left to say is ditch your OTS tune and get a custom tune. I cannot stress enough how much of a difference it makes for the car PLUS how much you can learn. Just goofing off with the programs and seeing the changes Mark made to my car and how it reacted was eye opening and being this was my first forced induction car, I was definitely glad to have some great people helping me along the way. This is really just the beginning of the S4 and what it is capable of. My block only has 68k on it right now and I am hoping to get the built one in around the 100k mark. So I should have about 2-3 years to get there.
Big things to come for this turd so stay tuned!
EDIT: First time ever at a drag strip
First off holy shit is this car not friendly when launching. I never got a chance to use the 2step because my street tires would have just been blown into oblivion. I was J135 and my first pass of 16.8 @ 104.56, I used no boost in 1st or 2nd. Finally matted it halfway though 3rd. The reason I babied it so much is because on the way to the track my clutch was slipping and I was really concerned it was not going to hold up. My second pass of 15.1 @ 103.72 I matted it from 3rd all the way, but I missed 3rd gear.
My next 2 passes were my best 2 passes of the day. 3rd pass was 14.5 @ 101.66 and I missed 4th gear. At this point I was trying to give it boost in 2nd gear and the torque steer was pretty annoying. The 4th run was my best of the day of 14.4 @ 105.86. Still had tons of wheel hop and plenty of torque steer.
My 5th and final pass of the day if you check the time stamp was shortly after the 4th pass. And a rookie mistake I left the car running almost all hour long between the runs. So my car was heat soaked like crazy. Ran 15.3 @ 106 and I used the flat foot shift from 3rd to 4th that run. Unfortunately my clutch went back to slipping after that and that was the end of my day.
All in all I am pretty happy for my first time ever running at the track. The car is capable of much more, but I need to work on my driver mod and get some better tires/wheels/suspension to help put the power down.
There she sits after her first day at the track. Super excited to get back out and learn more about the car.
BNR S4
HTP 3.5" Intake
JBR 3 port EBCS
JBR 88-duro RMM
JBR 80-duro PMM
Damond EGR delete
V2 Accessport
JBR Trans Mount
17"x9" Wheels
ISC Coilovers
Strut Tower Brace
2 point Under Brace
