Mysicksi
Hey all. I recently drove my 2011 MS3 for about 30 minutes with no issues. After I parked it and came back to turn it on, I started to throw two codes, along with the traction control light staying on. The codes are P0098 and P0108.
Here are the steps I have taken so far
-Replaced both the IAT and the MAP sensor
-Reset the ECU by disconnecting the negative battery terminal and pumping the brakes 5 times
-I tried to clear the codes multiple times with my access port
Nothing has worked so far. Does anyone have any ideas on what the next steps would be? Thank you.
