SOLVED
Year/Make/Model: 2012 Mazdaspeed 3
Mileage: 150,000 kms / 93,000 miles
Concern: Motor sputtering/misfiring under load near/in peak boost
DTC's: P0300 Multiple/Random Misfires Detected, P0302 Cylinder 2 Misfire Detected, P0403 (EGR Delete)
Modifications: Cobb AP v3, Cobb SR Intake, Cobb Turbo Inlet, Forge BPV, Autotech HPFP, JBR 80A RMM, Corksport Catback (No Muffler)
ECU/Tuning Software: AP v3
Tuner: Cobb OTS Stage 1+
Is the concern intermittent?: Yes
Can you duplicate the concern?: Yes
Recent Repairs:
- Coil packs replaced with OEM, spark plugs inspected and cleaned, compression tested at 135,000 kms (Cyl 1 180, Cyl 2 180, Cyl 3 185. Cyl 4 165)
Within the last week (Sept 20) in the morning while driving, I gassed it in third to drive thru a yellow, but by the time i got to the other side of the light, the car was violently shaking and the motor seemed to be choking with audible misfiring, CEL started flashing during the shaking then remained solid (EGR) after the shaking. This is my first instance of this occurring ever, and first motor issue overall. It was around 12 C (53 F) in the morning when this occurred. Around noon, I tried to replicate this issue cause I figured maybe it was temperature related in the morning, and couldnt replicate it. Around 4 pm I was able to replicate the issue, but it seemed that the severity in shaking dwindled a bit. The next day I replicated the issue again (26 C, 78 F), but this time it seems to shake alot less violently and my CEL didn't flash, but the stuttering had still occurred toward the latter end. I have had small amount of hesitation in power between shifts since then, but not very often. I've ruled out any boost leaks as im still able to maintain boost during a pull, originally thought it was the EBCS or hoses, but they all seem to be in good condition still. Im just puzzled as to where to go with diagnosing this. Thought it was motor mount or boost leak originally, but my current suspects are that my spark plugs are fouled, or may need to be changed (last change was at 110,000 kms, 4 years ago, gapped to 0.028), or maybe something MAF related? PMM to be replaced soon as well. Will look into these during the upcoming weekend. Not the greatest at reading logs adequately, but the log attached is me replicating the scenario where this instance occurred in the first place. (Cell 624 to 655)
Thanks in advance lads.
Recent Repairs:
