Bearded Jersey Devil
The general rule of thumb is that WOT knock under 2.0 is of no consequence, and that's on stock pistons. Personally, I like staying below 1, but I'm just super-careful. Fortunately, with all the alky going through my engine, it's not at all an issue. All I have is the characteristic (and totally normal) throttle tip-in knock. The durability to knock would likely be higher on 4032s and especially 2618s. But with enough alky and a solid tune, it's a moot point. You won't have knock unless something mechanical is going on, and if that's the case, you've got potentially much bigger fish to fry.
Yea, pretty much what I figured. I'll try to keep you posted. There are actually 3 local ms6 guys who will be running them. One of the guys should have his motor back in the next week or so, but he is still debating which turbo he'll be running. I'm currently running a 3071 that I'll be squeezing out every bit of power possible, but may try to pick up a 3076 because easy swap and should help hit 500... Hopefully.
