ConeKiller
Motorhead
Custom Endlinks
Fronts:
Two right threaded and left threaded, ½-20, Teflon lined, aluminum rod ends :
http://www.fkrodends.com/ALRSMALRSML31.html
½-20 Jam Nuts
http://www.fkrodends.com/STUDDEDSPEC42.html
½-20 Turnbuckle Sleeve
http://www.mcmaster.com/mv1469731222/#catalog/8419K36
Sleeve for Bolts
http://www.mcmaster.com/#catalog/122/3744/=13iz8ku
Washer Insert for Rod Ends
http://www.mcmaster.com/#catalog/122/1240/=13iz90m
½-20 bolt, lock washer and nut to match.
Rears:
custom U channels with a m12 bolt that goes through the control arm, a flanged nut attaches it at the top.
3/8-16 Teflon Lined Rod Ends
http://www.mcmaster.com/mv1469731222/#catalog/60745K441
http://www.mcmaster.com/mv1469731222/#catalog/60745K241
http://www.mcmaster.com/mv1469731222/#catalog/95034A300
The same sleeve for bolts.
3/8-16 bolts, lock washer and nut
Just that easy.
Fronts:
½-20 Jam Nuts
Sleeve for Bolts
Rears:
Just that easy.
