Bad update:
About a month ago I dropped to 2nd to pass some jackass doing 20 in a 40, and a pop with coolant all over the place. I feared the worst, but I coasted the 0.25 miles to my place and shut the motor off as I rolled into the driveway. Upon inspection, I found that my water neck/thermostat housing had shattered to 4 pieces. I believe I had put the original 2006 thermostat housing on during rebuild unknowingly, so at this point put the upgraded housing and tstat back in the car, flushed the system, and proceeded to keep driving it.
Drove it for a few days this past weekend and the car was strong. A few pulls had me happy to have her back, and decided I was going to drive it to work the next day. So on my drive yesterday morning, I boosted and the car was still fast and nothing seemed out of place, except for quickly rising coolant rates. Nothing out of hand, figured it just needed burped a little more. When I did boost during the drive, however, the coolant temps dropped quickly once I got off throttle. Like 199, boost, and down to 183 quickly.
Anyway, I park the car and leave it for 4 hours. When I come back out for lunch (and to get some water wetter) the turbo immediately sounded funny, and I could not boost at all. I took off early and drove home, and started tearing down. Turbo has about 1mm of shaft play both up/down and in/out. Bearing sounds like shit. Exterior edge of impeller is slightly worn down. Oil and coolant feed lines had fluid in them. No visible coking.
I havent blown a turbo before, but it seems a bit odd that it failed that quickly with no intermediate issues (low boost, slightly increased noise). I am also starting to wonder whether my coolant and turbo issues are somehow tied together. I guess I am just looking to try to talk some of this out, and see if anyone has thoughts on the matter. I know I have to rebuild turbo, but while getting into this I dont want to miss anything in fear of it happening again. Thanks for the long read.
