Another Crank but no start
mpanelli
Hi, This is my first post to the site and hoping to get some guidance from you all.
I did do a search on the subject and found a post (from rotarynerd) that the problem was was similar to mine and gave some great diagnostic advice but the difference is his problem did not throw any codes.
I have a 2008 basically stock speed 3 with 150k miles.
The problem.
I was driving about 45 miles an hour and all of a sudden the car died. The car will crank but no fire.
When I pulled the codes i saw
P0091, P2101, P2009, P2088, P0403, P0443, P2128
I will start working on the car Saturday so I havent done much diagnostics.
I checked the grounds and the main fuel pump and believe that the car did not jump time. The number of codes and type really concern me.
I am looking a for starting point on this.
I really appreciate your help
Hi, I don’t mean to necropost but I came across this thread and have the same issue and was wondering if this was ever resolved, my grounds all seem fine, and while the key is in and turned there is a slight ticking from the ecu near the battery, is it possible theres a problem with the ecu?
my dude OP hasn't logged in since their initial post in 2021 I don't think you're going to get an update. the post you quoted is someone else trying to help.
I'd make your own troubleshooting thread with your issue using the pinned post in this section as a template
