As DM would say "Bye-Bye blow-by" going full retard on PCV system
Need2pu
So! got a built motor, got a BT and I got crazy blow by, but compression is good... WTF right?
I had a JB turbo last year and never really noticed the burning oil smell, but this year I am on a BB turbo so I am smelling and am consuming a lot of oil. Weeks and weeks pass trying to find where in the shit its going because compression is still good! (210,210,205,210) I had given up and just went with the idea that it was big ring gap because 35+ psi dawg.
Long story short of how I found it... I was taking the manifold out and saw what I thought at first was the drain line leaking, so I decided to pull the turbo out and I saw that the leak was actually coming through the hot side:
I pooped a little when I saw this but I called PTE and they said the turbo is fine and that its one of two things, too much crankcase pressure or a bad drain set up, so I changed my drain set up to feed out of the turbo on a straight fitting, swooping into a 45 then into the block.
But now I have to take care of the CC pressure, I've been adding things and venting all the things to try and stop my dip stick from blowing out, but since I got rid of the K04 I stopped pulling vacuum on the system, needless to say that is changing now that I almost lost my turbo and all of my oil. Pictured below is my set up, yes 3 catch cans, added port, air oil separators, the whole 9.
Parts list:
1. 3- http://www.mcmaster.com/#7775K14
2. 6- http://www.mcmaster.com/#5346K66
3. 5- http://www.mcmaster.com/#5346K65
4. 8- http://www.mcmaster.com/#53525K22 (should only need 6 since DM plate comes w/ 2)
5. 15 to 20 feet of 5/8" rubber hose (buy from local parts store its only a couple bucks a foot)
6. 1- http://www.shopmoroso.com/eb/catalog/navigationPath/1::Moroso Performance Products/60000::Air-Oil Separators/6001::Universal Fit/{37685}::Air-Oil Separator Universal Kit, Small Body.html?entryId=catalog.productgroup.1600006001&expand=true&menuId=main.menu (need to replace their fittings with item 4)
7. 1- http://www.ebay.com/itm/252249520270?_trksid=p2053587.m570.l5999&_trkparms=gh1g=I252249520270.N36.S1.R1.TR3
8. 1- http://www.ebay.com/itm/Baffled-Alu...503799?hash=item3cfa3f81f7:g:FmUAAOSwBahVGBEu
9. 1- http://www.hstuning.com/product_info.php?products_id=936 (since JBR stole this design I feel better buying it from 42 instead of JBR :) )
10. and of course lots and lots of hose clamps or zip ties for all the connections!
For the poor saps who see it in years to come, post up the details!
