Need2pu
So! got a built motor, got a BT and I got crazy blow by, but compression is good... WTF right?
I had a JB turbo last year and never really noticed the burning oil smell, but this year I am on a BB turbo so I am smelling and am consuming a lot of oil. Weeks and weeks pass trying to find where in the shit its going because compression is still good! (210,210,205,210) I had given up and just went with the idea that it was big ring gap because 35+ psi dawg.
Long story short of how I found it... I was taking the manifold out and saw what I thought at first was the drain line leaking, so I decided to pull the turbo out and I saw that the leak was actually coming through the hot side:
I pooped a little when I saw this but I called PTE and they said the turbo is fine and that its one of two things, too much crankcase pressure or a bad drain set up, so I changed my drain set up to feed out of the turbo on a straight fitting, swooping into a 45 then into the block.
But now I have to take care of the CC pressure, I've been adding things and venting all the things to try and stop my dip stick from blowing out, but since I got rid of the K04 I stopped pulling vacuum on the system, needless to say that is changing now that I almost lost my turbo and all of my oil. Pictured below is my set up, yes 3 catch cans, added port, air oil separators, the whole 9.
Parts list:
1. 3- http://www.mcmaster.com/#7775K14
2. 6- http://www.mcmaster.com/#5346K66
3. 5- http://www.mcmaster.com/#5346K65
4. 8- http://www.mcmaster.com/#53525K22 (should only need 6 since DM plate comes w/ 2)
5. 15 to 20 feet of 5/8" rubber hose (buy from local parts store its only a couple bucks a foot)
6. 1- http://www.shopmoroso.com/eb/catalog/navigationPath/1::Moroso Performance Products/60000::Air-Oil Separators/6001::Universal Fit/{37685}::Air-Oil Separator Universal Kit, Small Body.html?entryId=catalog.productgroup.1600006001&expand=true&menuId=main.menu (need to replace their fittings with item 4)
7. 1- http://www.ebay.com/itm/252249520270?_trksid=p2053587.m570.l5999&_trkparms=gh1g=I252249520270.N36.S1.R1.TR3
8. 1- http://www.ebay.com/itm/Baffled-Alu...503799?hash=item3cfa3f81f7:g:FmUAAOSwBahVGBEu
9. 1- http://www.hstuning.com/product_info.php?products_id=936 (since JBR stole this design I feel better buying it from 42 instead of JBR
10. and of course lots and lots of hose clamps or zip ties for all the connections!
Parts list:
