piterus87
Hello everyone.
My English is not perfect so I have to help myself with a translator.
I have a big problem with my mazdaspeed3 / MPS. maybe someone will think of something or have had a similar action with his car.
Patient: 3 MPS BK / Mazdaspeed3
Symptoms: After starting the car, it shakes a lot when it is cold, it is like 3.5 cylinders, it farts and farts from the exhaust. Symptom similar to a misfire or mega leak in the intake. Zero errors.
What I have already checked / replaced:
- MAF x3,
- regeneration of 3 injections + one new one + new washers
- crank sensor and shaft sensor - replacement for another
- MAP sensor - new from Bosch
- a set of coils - 2 sets of new spark plugs
- second harness for coils
- cleaned EGR
- inlet valves cleaned
- new original lambda sensor (the one in front of the catalyst)
- proven compression probably 6 times - anywhere between 12 and 12.5 bar
- Solenoid from the vacuum in the inlet - replacement for another used one.
- pressure test of the entire inlet - small leakage at the PVC valve - eliminated
I probably forgot to mention something above because that was it, but I replaced most of it.
After regeneration of the injectors for about a week, the car drove almost normally (it felt very gently, as if it was cutting its power slightly, but it was possible to drive). After this time, I replaced the spark plugs with new ones and the problem came back again (I think it's just a coincidence). The return to the old candles did not help, the exchange for another new set - also no effects. I'm starting to spread my hands because all the potential causes have theoretically been eliminated and the car is still working like shit and I can't drive it.
STFT normal, fuel pressure normal, pump pressure in the tank is approx. 4 bar on the rail
I do not know if it is possible that any injection after regeneration died so quickly? Injections regenerated about a month ago.
Below is a video of how he works after a cold start.
I will be grateful for all suggestions on what could be the cause or what I should check
- MAF x3,
- cleaned EGR
