Turbo Problem
Daniel Castro
Recently started seeing smoke coming out my hood and realized that the turbo was smoking. It is a white color smoke and I do see that the turbo is wet in between the cold side and hot side or simply where all the return lines are at. I will also get blueish smoke coming from the tailpipe of my exhaust but only when if been driving it around for a good 20-30 min and let it sit for about 3 minutes idling. It will smoke for about 2 minutes and it will go away. Could it be my turbo seals are blown although it may not be the case since there is no oil in the throttle body and I’m not sure how Long the BNR S1 turbos last but it has around 45-50k miles on and it still spool up really good.
