Lex2007
90% people won't cross shop these two setups. I know. But after 10 years on V3s, two returns for repair of the rears (over 80k-90k miles), failed repair of the fronts and maybe because the ride deteriorated as the fronts wore out over the years I got tired of KW.
Maybe I just got tired of dodging imperfect pavement.
The V3s were incredible on smooth pavement. So much control. Car looked amazing sitting low. If you dont drive in the city, get them. You will love them. But even in the softest settings I was bouncing around in the city. To the point I was losing traction. Ya cant drive fast if you need to dodge every bump in the road. Maybe my impression got worse as the front struts deteriorated. 10 years is a long time.
The front struts went in to KW two months ago for a revision for the first time and they said they were fine. Hard to believe.. 10 years old 90k miles and like new eh? I did tell them they were squeaking like crazy over medium bumps. LOUD. Embarrassingly loud. I had to remind them while the struts were at KW to please check for squeaks and then they claimed they took care of it. When I reinstalled them, still squeaking.
This is despite changing every bushing on the front suspension. No squeaking with Bilsteins installed. KW fixed nothing.
The "experts" at KW also sold me 280 inch pound springs for the V3s which weren't intended for my setup. They apologized after the fact when I found I was riding on the bumpstops. Not once did they didnt offer a refund. Keep ya $200 ya fools...
I got the B12 Prokit installed on Sunday. Had to pull old parts off the ancient Koni Yellows with OEM springs I was using 10 years ago before the KW V3s went on.
I need to get an alignment before I drive much more but of course the difference is drastic. 220 vs 400 inch pound and much more suspension travel. I wont say more till I get I seat time.
KWs with rear bottomed out, front with plenty more lowering possible but any lower and will be rubbing fender wells on hard turns.:
With Bilstein B12 Prokit fresh outta the box, not settled in yet:
