These cars are very sensitive to plug gap it seems. It needs to be 0.025-0.028; never trust the pre-gapped plugs either.
What is your HPFP pressure at when you turn the car off after driving?
What is your HPFP pressure with the car on at idle and at WOT?
Do you hear any chirping?
Okay sorry for the late reply things have gotten a little busy around me, but I had about two hours of free time and I think I definitely found the issue of my problem for the misfire.
But I want to know the cause of it, so I thought you know what I'll pull my plugs and get an idea of what's happening, so I took off the top mount thinking it was the coils for the plugs, but those are still in perfect shape.
When I pulled the first plug, my mind blew holy shit how did this happen, I've never seen the tip of a sparkplug actually break, all of them were terrible 1,2,4 were white like if the plugs were too hot. And plug three was pitch black.
I also noticed alot of oil on the inside of the intercooler, as well as the couplings, for the turbo.
I'm about to test the waste gate with compressed air and see how that goes but this so far is my BIG find
EDIT1: So I just now tested the wastegate and it's as smooth as butter, went back and fourth very easily, this leads me to believe the EBCS is bad? Or is there anything else I should look at first.
EDIT2: So after putting new plugs in(same NGK Lazer iridiums, car is so far starting fast and it doesn't smell like a dump of fuel on startup. I cleared the P0300 light and and am going to be testing the car on the way to and back from work.
