AYOUSTIN
wait, all this work and you are still on the stock block?
Yes indeed. I've got most of the stuff for an engine build, just missing bearings, fasteners and gasket stuff.
Wasnt the engine already out though? Or maybe not, I thought you pulled it.
Sub. Want to read thread later. I has a twinscroll setup.. much easier to fit it into a 6 though lol
tapatalkin
How is the Damond mani adapter working for you? Still waiting patiently on the MS6 specific kit (if there is one), but I'm really interested in cold pipe solutions, seeing as there's a bunch of crap down where the new throttle body location is.
You'd better hope your car is up and running more often than this guy right here.
Any word from DM guys? I'm actually pretty interested on flipping the routing like you did because I had an idea of tapping the windshield wiper reservoir for meth, and it'd be a straight shot from the tank to a throttle spacer. Could be more work than it's worth, but I like creativity.
Also hope the fueling is coming along well, can't wait to see the final product.
Interesting. That does look like quite a tight squeeze after the IC. I was thinking essentially the same route as most conventional set ups, just flip sides. So was there not enough room to go around the radiator support, the angle up from there on the passenger side?
Looking good. I'm curious why you're running only 6 degrees @ 6,700? I forgot the exact nature of them, but I've read from some of the reputable tuners cautions about running too little timing, and how it can be dangerous. I think the rule of thumb is you want at least ~10 degrees @ redline. Someone, please feel free to correct me if I'm wrong.Well, worked a bit on the tune some more today. Going to do more work tomorrow. Really only touched timing today, I'm happy with how timing looks but I'm going to have to extend it further tomorrow which means redo what I just redid lol.
Threw one of my runs into VD and I'm pretty happy with what I'm seeing. Fueling is pretty clean, 20psi and 6* of timing. I was running the same amount of timing before but at a lower load value so it'll be interesting to see what happens as I move further up. I've added ~6* and that picked up around 50hp (this is also a couple PSI higher). Ambient temps were around 45F so it's pretty cool to see BATs only 15-20F higher. Looks like IDCs are going to run out soon but I don't really want to venture much further than 20psi on 93 so I'm going to turn on the fueling kit to bring my IDCs down and get some cooling effect to hopefully raise my octane ceiling a bit and just make the rest of the power with timing. If I could get 350whp on 93 I'd be VERY happy.
Lastly, I was really happy to find a gas station like a mile from my house that has E85! I'm really getting antsy to throw some in.
Eibach Race Springs line, right? I've always heard such great stuff about Swifts, and I ran their Spec Rs before going to the Ground Control setup. I was very happy with them. In terms of conventional performance springs (not coilover springs), I still think they're tops.Today was full of excite. I bought wheels and tires from Phate 17x9.5 Enkei NT03+M with 255/40 RS3s. Hopefully I'll get to have some fun before winter hits.
I also finally got my rear springs! I'll be throwing them in tomorrow or Wednesday.
