Once again, I didn't get as much done as I wanted this past weekend but here's where I'm at:
- Passenger side fuel tank tophat is out and will be mounting additional fuel pump to it this week. This weekend I'll put it back in the car and run the feed and return lines and get it wired up.
- Shifter cables are in the car but the bracket has to be modified one more time because one of the cables is in the way of the intake.
- Vacuum lines are rerouted and I'm waiting on a vacuum block to connect them to.
- Started stripping front engine harness to move some wires around.
- Chopped up old brackets to mount the purge solenoid, ignition capacitor, and EBCS elsewhere.
- Got the manifold all set to go into the car except for the vacuum fittings and I'm waiting on my 4 bar map sensor to come in the mail.
- Figured out dimensions for a mounting bracket to hold both SS controllers, will make that bracket this week.
- Started dialing in the shifter cables. I think I've got them just about right but 4th gear feels a bit shorter than the rest (it doesn't pull back as far as 2 and 6) and I can't remember if that's normal or not. It's also pretty touchy about going into 1st and 2nd. If I pull to the left too hard it won't go into gear. I'm sure I can get that fixed with more adjustments but I'm still unsure of the 4th gear thing, if someone could check that for me it'd be appreciated.
I've got a long weekend this coming weekend so I'm hoping to get a good chunk done and have the car fired or just about ready to fire the weekend after. Still waiting on some parts so hopefully that doesn't hold me up.
