Bighern9999 Greenie Member Oct 11, 2022 #1 So since I bought my MS6 I have not been able to use the key FOB. I have a tried to the procedure but will not go into program mode to to learn the KEY FOB.
Easter Bunny Professional Engineer Motorhead Oct 11, 2022 #2 You need to have two already programmed keys to program a third
Bighern9999 Greenie Member Oct 12, 2022 #3 I have only one, so the vehicle needs two keys to program the fob.
Awafrican Moderator Oct 12, 2022 #4 Correct you need two. you'll need to go to the dealership for them to do it if you only have one
Bighern9999 Greenie Member Oct 12, 2022 #5 Awafrican said: Correct you need two. you'll need to go to the dealership for them to do it if you only have one Click to expand... Thank you
Easter Bunny Professional Engineer Motorhead Oct 12, 2022 #6 you need two working ones in order to program a third, otherwise you need to go to the dealer
