dangitbobby
I've had a slightly rough idle for a while now, no codes or rpm fluctuation, but it sounds and feels like a small sputter/pop every few seconds, only when fully warmed up. 2010 with 62k miles, injectors and valves recently cleaned. Logged HPFP pressure after turning the car off and pressure only rose to 1400 so I replaced relief valve (autotech internals btw). Afterwards, I did the same test after a drive and pressure only reached 950, but then the next day reached 1700. My HPFP pressure has never looked bad in logs or cruising around, except for occasionally dipping into the 390s for a split second at idle before going back up to around 415. Also, pressure is always around 250 on decel, but not sure if that's normal or not. Either way the rough idle was still there so I cleaned and rebuilt the HPFP with the CS kit. Now the idle is slightly worse and LTFT is consistently around -10, -11 at idle and no change to HPFP pressure. The car drives perfectly fine when not idling and fuel trims even out. I've also checked for vacuum leaks a number of times. Any advice on what to check next?
