Chasing Codes - P2089 & P0012
SPINDUX
Hey all,
Posting on behalf of a friend who recently built a new engine for his Gen 2 Mazdaspeed. It’s a solid setup with Manley rods, CP pistons, Kelford cams, R35 ignition coils, and more. Initially, everything ran perfectly, including some track time.
However, things started going south after our tuner uploaded a ghost cam tune. At first, it seemed fine, but over the course of the night, the idle progressively got worse—becoming so lumpy it could barely hold idle. Swapping back to the original tune didn’t resolve the issue; the idle remained fully advanced and rough. This was fixed by replacing the OCV.
Unfortunately, the car is still having issues with the OCV/VVT. It stutters when transitioning into DOHC, though it drives fine as long as you stay out of boost/DOHC. Our tuner checked remotely and mentioned he couldn’t see the OCV activating.
The current error codes are:
P2089 (always present)
P0012 (shows up after driving for a while)
Troubleshooting so far:
- Checked the wiring between the OCV and ECU—all good. Replaced the wires as a precaution.
- Sent voltage through the harness to activate the OCV—confirmed it works.
- Replaced the OCV and cleaned the filter (tried three OCV valves).
- check timing with corksport timing kit, all okay
Despite all this, the issue persists, and we’re stumped. Any insights or suggestions would be greatly appreciated, before he send off the ECU to get tested.
Thanks all :)
Check the crank position sensor for dirt/ grit
Otherwise might need to re time the motor
Yeah was thinking of putting a new crankshaft positioning sensor into it.
I have a new OEM one in my car that I will try !
Also forgot to add, we have checked the motor is in time
This is also the wear on the cams. Unsure if it’s normal
What do the codes mean and do you have a log of a cold start?
Edit: What size intake and who's the tuner?
