Thanks for all the kind wishes everyone. Really sucks that this happened, and I'm prepared for functionally a full suspension replacement being needed in the front. Definitely will need LCAs both sides, struts and springs both sides, at least right side CV axle, both sides tie rods, front right fender, and front left ABS sensor wire so I can hopefully have ABS working again after the car is fixed. Really hope my Whiteline front sway bar and CS front endlinks survived. The silver lining I suppose is that the front suspension was on the verge of needing replacement anyway, with my bumpstops having mostly flaked away and the dampers feeling quite blown, as well as the lower ball joints being basically seized into the uprights and needing to be forced out. Hopefully when she gets fixed she'll be back better and more capable than ever, and even if (God forbid) she's totaled, I will do everything in my power to keep her and get her back on the road myself.
