Arron Wright
After wasting away 3 days trying to bleed a clutch. Here is the moment I figured out what was wrong…..
Gravity bleed, pressure bleed, or using a friend to pump the clutch will not do you any good if the car is not level. After many hours of cussing out anything and everything, I finally decided to remove the battery box again after I just change out the master cylinder to attempt to bleed from the bottom of the master cylinder. I kept adding fluid between pumps and was getting little flow thru. Even thou the reservoir was full, the back end where it feed the clutch line was lower than then the flow tube. I had my car jacked up from the driver side to have alittle more access and by doing so it tilted the reservoir to an air bubble. Once I lowered the car back down to level, it literally only took 3 openings of the bleeder valve to be back at 100%. My method was pump the clutch pedal about 5 times and leave it against the firewall. Then I use a hand vacuum pump from harbor freight ($25) to build 15-20psi and then with one hand manually force close the slave cylinder and then using 9mm with the other hand to open the bleeder. After each cycle, I would make sure to top off the reservoir. On the third round the pedal was to stiff to stick to the floor so I just left it up. I’ve read to many posts of people having problems with this and wanted to share my experience.
