john michal
I'm gradually assembling a Frankenmobile- a 2006 speed six. Clutch pedal is either up or down, nothing in between. I started with opening the slave bleed screw, but no fluid. I disconnected the slave supply, but no fluid. I disconnected the slave supply at the clutch master, but no fluid. I disconnected the the supply to the master from the brake/clutch reservoir. Fluid comes out of the reservoir. I disconnected the master supply at the master and fluid comes out. I tried pumping fluid into the master, with no positive result- nothing changed at the pedal, nothing came out of the slave side of the master. Sticking my head under the dash and observing the action of the clutch master activating (?) rod, I notice that after it moved straight in for a short distance the rod moves upward and cannot be centered in the master cylinder bore. Bad master cylinder? Big deal to replace?
