UPDATE: 4/2020
After using this for a while it appears that the speed 6 bore is not going to work with the speed 3 master cylinder. It creates too much pressure for the master and screws it up. You can use this guide to make your own 3an line setup but for now this is not a solution.
UPDATE 2: !!! 1/7/2022 !!!
It seems like the 2005 Lexus IS300 slave is am almost direct swap "still need new lines" and matches up to the bolt holes. If anyone can try this let me know and I will update this thread.
The speed 6 slave is pretty cheap, reliable and rebuild able. I was looking to do stainless lines to replace my 155k miles rubber lines and figured I could covert to that as well. @CMajor Had installed the 6 on his and it was working well so I decided to go for it.
Tools needed
Tools needed
- OTC 4503 Stinger Double Flaring Tool Kit
- Steel Tube Nut, 1/4 (7/16-24 Inverted) "goes on OEM line"
- Fragola (481503) #3 Union Fitting Adapter "used to connect two 3an lines as I had two on hand you could just use a single long one if you really wanted to"
- (E-11-9) -3AN Male To 7/16-24 Female SAE Brake Line Fitting Adapter For 1/4" HLF02 1pc "for OEM hardline to convert to 3an"
- Stainless Steel Braided Brake Hose Line -3an Straight W/90 10" Long Clear Coated "used this for the run from the firewall to the Union"
- You will need another line if you are using the union. 12" maybe , it's been a while since I did this.
- ???? I don't remember and can not find the fitting that needs to be on the speed 6 slave
