Car: 2012 Mazdaspeed 3 2.3L
Issue: No recent changes or accidents, car worked fine one day and next day would not start. Installed new battery and no change - 13.8v measured. For diagnostic tools I have a Cobb AccessPort, OBD II with Forscan, test light, multi-meter and backprobes. No oscilloscope unfortunately.
Fuel: I can hear low pressure fuel pump engaging and smell fuel throughout tests, AccessPort ranges: injector duty cycle 1.3-5%, Injector pulse width 6.90-7.1ms, HPFP desired pressure 1015psi, HPFP actual pressure 925-1313psi
Sensors: I replaced the Crankshaft sensor and verified 20 tooth alignment with TDC. I backprobed the Camshaft sensor and values are as expected. I disconnected the MAF sensor for one test.
Compression: sounds normal, compression tests were performed and good 9 months ago
Fuses/Relays - checked all the obvious ones and they look good
PCM (ECU)
Thanks,
Dave
PCM (ECU)
- There are no codes.
- I performed a continuity test from 2nd and 3rd coil connector signal wires, through coil pack wiring harness to the PCM connector. Both good, assumed others were as well.
- Inline plug tester shows no spark on any cylinder, pulled plugs and they look normal. Grounded plugs and cranked - no spark
- Grounds: I inspected and cleaned main ground near battery and chassis ground near HPFP (which is used for ignition coil GND). Measured voltage drop from battery terminal to HPFP chassis ground was 72mV. I also connected a separate wire from this ground to battery negative with no impact. I also performed continuity test between this ground and ignition coil GND. All 4 show 54 ohms of resistance.
- Ignition Coils all 4 show similar results using multimeter:
- +B: 12.48v key ON, drops as low as 10.9v on crank
- Gnd: 70mV key ON, +or- 20mV on crank
- Signal: 0.33v key ON, on crank most values <0.5v but a few spikes to 2.1v
- Is the coil connector GND to chassis ground resistance of 54 ohms an issue? Anything else standout with my ignition coil measurements?
- Can anyone think of anything else I should be testing?
Thanks,
Dave
