Crank position sensor error on 2nd gen MS3 need help
Etienne Gagnon
Hey guys, I am looking for some help, I have a crank position sensor error code on my newly swapped 2013 MS3. The car runs fine and there are no issues with power or anything.
I don't have the tool to screw into the back of the block to set the CPS so I am wondering how you guys clear that code? I tried with my scanner and it comes back on next time I drive the car.
thx
Cleaned it and tried 2 different ones. Car runs fine but I get the code with both. Should I try moving the sensor a bit to see if it clears it up ?
If you're running a bigger intake you may need to zero out any cells in your MAF below 2.0 g/s (if you get the issue on startup).
Edit: Might actually be zero out any cells below .9 MAFv
