Juschiln19
Silver Member
This build starts with a little history. I purchased a 2006 speed 6 in 2015 for $7600. In Beautiful Mica Black with panda interior
Pre existing problems:
-Keyed down the side of car (Whole passenger side)
-2 motor mounts shot
Mods came with:
-Turbosmart Dual Port BBV
-Sure MAF Housing 2.5" Id
-Spectre CAI Cone 3" Id
-Strut Brace
(Pictures of car and engine bay day after purchase 2015)
Over the last 5 years I did alot. Nothing cosmetic besides new gen 2 rims. I Love the sleeper effect this car has!
So I was just slowly building the car with the intention of building the motor in the future.
Here is the setup I had:
-BNR S4 V2
-Grimmspeed Ebcs
-Guardian angel
-HTP 3.5" Intake W/Recir. Tube
-2in1 oil sandwhich plate
-Transfer case bearing caps
-Engine M Drian plug w/C washer
-Sure Diff Mounts
-Sure Intake manifold Theromo Gasket
-Sure Throttle Body Theromo Gasket
-Denso 1 Step Colder Plugs
-DM STAGE 3 Dual Occ's
-DM Pcv vent plate
-Rev 5 Oil cooler kit
-Whilteline Rear sway bar
-GS Oil pressure guage W/Alarm
-Adju. Sway bar linkage(rear)
-Oil return and feed line gaskets
-Bosch 3.5 Bar Map
-Map sensor adapter plug
-ContinentalExtremeContactDWS06
-Mazda 3 Oil Filter Housing
-Rotella T6 Oil
-SouthBend Stage 2 Clutch W/Lightweight Flywheel(9lb lighter then stock)
-Autotech hpfp internals
-Fmic (Tr6 core)/CX Racing Pipe kit
-Custom gauge vent pod(Block8Head)
-GS 3in1(Boost/oil temp/oil pressure)
-VersaTuner ($100)(Base 91 Map)
-Ebay 3" Catless Dp (both cats deleted)
-EBC Stage 4 brake kit (W/ slotted rotors & red stuff pads)
-SS Brake lines
-SS Clutch line
-Strut Brace
(Picture of engine bay)
Well I got into a accident and rear ended a Ford explorer.
The crash bar saved its life. Insurance deemed it totalled.
I bought it back and fixed it with the pay out left over after the loan was paid off.
Tho multiply shops said it did not have frame damage. I believe that not to be true. The right fender is bent outward and the hood hits by hinge when opened.
(Picture of car after I repaired it)
I found myself in the position to finally build the motor and finish the full build.
Well Since the one I had has frame damage. I decided to search for a new rolling chassis.
I found a rolling chassis for $800 with a shot valve and some hail damge. Also in Mica black but with Black interior.
So I scooped it up and starting moving all upgrades to new one.
So this is the new setup:
-Overspeed Built Motor(Built For 700hp)(I'll include build sheet
-Grimmspeed Ebcs
-Guardian Angel
-HTP 3.5" Intake W/Recirculation Tube (recirculation tube blocked)
-4" to 3.5" coupler for intake
-St manifold W/PI adapter
-1000cc boush injectors
-Split second controller
-NGK 6510
-DM STAGE 3 Dual Occ kit(running route 3) -DM Pcv vent plate (not new version)
-Bosch 4 Bar Map
-Turbosmart Dual Port BBV(Full VTA)
-Rotella T6 Oil
-Fmic (Tr1035 kit w/crash bar)
-CPE exhaust Manifold
-Kosmic 3" DP
-Tial Mv-R 44mm Wastegate (17lb spring)
-PTE 5558 CEA Gen2
-Hellcat fuel pump
-Spin on oil filter conversion
-Sandwhich plate
-Sure Rear Diff Mounts(Both)
-ContinentalExtremeContactDWS06 tires
-GS 3in1(Boost/oil temp/oil pressure guage)
-GS Oil Pressure guage W/Alarm
-Fuel lab Fuel Regulator
-custom 3" catback with 2 vibrant ultra quiet resonators (single exit no mufflers or cats)
I opted to replace all sensors and all fail points (water pump, thermostat). My goal for this build is a 650hp daily
(Engine Build Sheet)
Currently I am still installing everything and switching everything over. I'll post updates as they come.
Mods came with:
-Strut Brace
-BNR S4 V2
-Grimmspeed Ebcs
-Guardian angel
-Sure Diff Mounts
-DM Pcv vent plate
-Bosch 3.5 Bar Map
-Rotella T6 Oil
-SS Brake lines
-SS Clutch line
-Strut Brace
-Grimmspeed Ebcs
-Guardian Angel
-NGK 6510
-Bosch 4 Bar Map
-Rotella T6 Oil
-Kosmic 3" DP
-PTE 5558 CEA Gen2
-Hellcat fuel pump
-Sandwhich plate
