Most people just used boost-referenced WMI systems. They work great, even for up to a CM10 spraying 100% methanol, like I use at my power level (390whp.)
If you're going to go over that with an S4, I'd go progressive controller that's boost-referenced. I'd probably recommend AEM, Cooling Mist, or Snow Performance over Devil's Own for the simple fact that a couple of Devil's Own controllers have gone wacky in the middle of the night and hydrolocked the motor with methanol. Apparently they're wired to a constant hot (instead of just a switched power source), so if they fail, it could be really bad.
I personally like Cooling Mist the most. Their Stage 2 controller looks like a digital boost gauge (with numbers, not a needle) and fits into a gauge pod. You can monitor boost with it too by leaving it in that setting mode, so bang-for-your-buck.
