jsilva
I recently bought a Speed6 which I’m working up and am unsure about a problem I’m currently troubleshooting.
Symptoms:
- When cold it will stall a second after starting. I have to rev the engine up to around 2500 rpms for 30 seconds so that it won’t stall.
- Before it warms up it has some significant hesitations/bucking when driving.
- When it’s warmed up it has a rough idle. Almost feels like it wants to stall but doesn’t. Hovers around 650-700 rpms.
- It has a loss of power.
I should say that this issue started after I replaced the fuel injectors (the injectors were new). At first I thought it was because of a fuel leak at the pressure sensor and a loss of fuel pressure—the fuel rail threads for the sensor were actually stripped and so I replaced the fuel rail along with the seals on the injectors and fuel rail. Leak stopped but problem persisted.
So I started wondering what else I did when I replaced the injectors and I assumed it was a vacuum leak, and it may be, but I haven’t been able to find it (though my only way to test is to spray around with carb cleaner while engine is cold). I did end up replacing the MAP sensor as well.
The only other thing that I did was I accidentally pulled the oil dipstick holder out of the engine/oil pan. It must have already been loose since it came out easily. I tried to get it back in but it’s possible I wasn’t able to get it back perfectly.
So then I wondered if an air leak around the dipstick holder might affect the pressure in the crankcase and cause the symptoms I’m experiencing?
Any advice would be greatly appreciated! Thanks.
Symptoms:
