maybe
in all seriousness it depends on the style of piston that you are using and if is is significantly taller than stock, i seriously doubt that you will have an issue but it should be verified while the motor is taken apart
Extreme duty. Like doodie. ha. Will look more when I get it all back. May just get a cometic .036" to be safe.it literally says extreme right in the product name!!!
still going with maybe, gonna just have to measure everything once it is in hand and then order a head gasket. or just order a thicker one and take the small compression hit.
