Engine TQ specs
Need2pu
This is a copy and paste from that other forum...
So I took the time to pull a bunch of engine torque specs from all-data. Enjoy, and let me know if you need any more and I can try and dig them up!
HEAD
Loosening order:
(I personally recommend a few loosening steps)
Tightening order:
Step 1: 3-11 Nm (27-97 in-lbf)
Step 2: 13-17 Nm (116-150 in-lbf)
Step 3: 43-47 Nm (32-34 ft-lbf)
Step 4: 88°-92°
Step 5: 88°-92°
(for stock bolts only!)
CAM CAPS
Loosening order:
Tightening order:
Step 1: 5-9 Nm (45-79 in-lbf)
Step 2: 14-17 Nm (11-12 ft-lbf)
VALVE COVER
Loosening order:
Tightening order:
8-10 Nm (71-84 lb-in)
OIL PAN
Tightening order:
17-23 Nm (13-16 ft-lbf)
CRANK BOLT
Tightening:
Step 1: 96-104 Nm (71-76 ft-lbf)
Step 2: 87°-93°
TIMING COVER
Tightening order:
Bolts 1-18: 8-11 Nm (71-97 lb-in)
Bolts 19-22: 40-55 Nm (30-40 lb-ft)
WATER PUMP
Tightening:
Bolts 1: 17-23 Nm (13-16 lb-ft)
Bolts 2: 8-11 Nm (71-97 lb-in)
REAR MAIN SEAL
Tightening order:
EXHAUST MANIFOLD
Tightening order:
43-64 Nm (32-47 lb-ft)
OIL PUMP
Tightening order:
Step 1: 8-12 Nm (71-106 in-lbf)
Step 2: 17-23 Nm (13-16 ft-lbf)
CAM SPROCKETS
Tightening:
69-75 Nm (51-55 ft-lbf) (both sides)
THROTTLE BODY
Tightening order:
FLYWHEEL
Tightening order:
151.3 - 161.1 Nm (111.6 - 118.8 ft-lbf)
PRESSURE PLATE
Tightening order:
Tighten in a MINIMUM of 2 steps ending with 25-33 Nm (19-24 ft-lbf)
FUEL RAIL COVER
8-10 Nm (71-88 in-lbf)
THERMOSTAT
TIMING COMPNENTS
Bolts 1: 8-11 Nm (71-97 in-lbf)
Bolts 2: 20-30 Nm (15-22 ft-lbf)
HIGH PRESSURE FUEL PUMP
(the E8 bolts) 9-11 Nm (80-97 in-lbf)
PCV PLATE
POWER STEERING DUMBY PULLEY
19-25 Nm (15-18 ft-lbf)
IDLER PULLEY
INTAKE MANIFOLD
Bolts 1: 17-23 Nm (13-16 ft-lbf)
Bolts 2: 4-6 Nm (35-52 in-lbf)
FUEL RAIL
1. 17-23 Nm, 13-16 ft/lbs
2. 22-25 Nm, 17-18 ft/lbs
3. 24-35 Nm, 18-25 ft/lbs
4. 8-11 Nm, 71-97 in/lbs
5. 17-23 Nm, 13-16 ft/lbs
6. 16-24 Nm, 12-17 ft/lbs
AwAfrican ninja edit to add fuel rail order
FRONT HUB
1. 236-275 Nm, 175-202 ft/lbs
2. 82-101 Nm, 61-74 ft/lbs
3. 64-74 Nm, 48-54 ft/lbs
4. 43-60 Nm, 32-44 ft/lbs
5. 4-6 Nm, 36-53 in/lbs
6. 38-50 Nm, 29-36 ft/lbs
7. 44-58 Nm, 33-42 ft/lb
STARTER
1. 38-51 Nm, 29-37 ft/lbs
2. 38-51 Nm, 29-37 ft/lbs
3. 10-11 Nm, 89-97 in/lbs
ALTERNATOR
3. 8-10 Nm, 71-88 ft/lbs
4. 8-10 Nm, 71-88 ft/lbs
5. 10-14 Nm, 89-123 in/lbs
KNOCK SENSOR
1. 16-24 Nm, 12-17 ft/lbs
COIL PACKS
1. 6-9.5 Nm, 54-84 in/lbs
BLIND PLUG
1. 18-22 Nm, 14-16 ft/lbs
CRANK SENSOR
1. 5.5-7.5 Nm, 49-66 in/lbs
CAM SENSOR
MAIN BOLTS
Step 1: 3-7 N-m (27-62 in-lbf)
Step 2: 23-27 N-m (17-20 ft-lbf)
Step 3: 38-42 N-m (28-31 ft-lbf)
Step 4: Loosen all the bolts (until bolts are torque-free)
Step 5: 3-7 N-m (27-62 in-lbf)
Step 6: 18-22 N-m (13-16 ft-lbf)
Step 7: 87.5°-92.5°
ROD BOLTS
Step 1: 26-31 N-m (20-23 ft-lbf)
Step 2: 80°-100°
OIL SQUIRTERS
7.8-10.8 N-m (70-95 in-lbf)
I will be updating as I get suggestions or find more!
Apparently this engine was not built by people with muscles. 60ft/lbs all the things.
except for the axle nut haha I had to barrow a TQ wrench for semi truck pinion nuts to torque my axle nuts, and no that's not a joke.
FLYWHEEL
Tightening order:
108-116 Nm (80-85 ft-lbf)
Looks like the torque rating was taken from the G35M-R and not the A26MX-R which is our transmission/turbo engine setup. They are just a few pages apart in the workshop manual so easy to miss. The right torque should be 151.3 - 161.1 Nm (111.6 - 118.8 ft-lbf)
updated, good catch and thank you much sir!
Awesome thanks for putting this together! Starting reassembly within an hr
Glad I could help, when I was building my engine I kept getting pissed when I couldn't find a spec or if I has to dig forever for one, drove me up a wall
  • Like
Reactions: J S
So the intake manifold.... is confusing. Where are all of the bolts?
Not every bolt will be in every picture, everything would be insanely cluttered if they but every bolt in every picture haha just tighten them inside out
I can't find the head gasket procedure in the workshop manuals. Do the head bolts call for any lubricant? I would think enine oil but I can't find any info anywhere.
Torque spec thread, not which parts to lubricate thread. :) Also I dunno, I'm being helpful right?
Good info. In the past I had to spend most of the time researching torque specs. Then it ends up the torque specs would be hand tight, hand tight + 1 turn, tight but not too tight, normal person tight, and muscle man tight lol.
