Engine TQ specs
  • Thread starter Thread starter Need2pu
  • Watchers Watchers 38
Anyone have the spec for the big banjo bolt that the oil filter adapter uses on a cx9? I know this is not a cx9 thread but I can't find it anywhere :(
The specs on here really have helped with my install and I appreciate it being on MSO. Hope more guys continue to be super valuable info on this great forum so I don’t have to look elsewhere!
Anyone know the actual specs for the oil pickup tube? Might be something else to add to this list as I am installing a new tube and o-ring on my engine this time around.
I went ahead and gave it some blue loctite and just tightened it fairly snug without obviously screwing anything up and stripping a bolt or something haha Just would be good for others down the road.
I haven't looked myself however have you looked at the workshop manual? Should be able to find it in there or the assembly manual, we have them in the metal member section.
https://mazdaspeeds.org/index.php?forums/mazdapeed-owners-manuals.193/
Super super helpful main man
Anyone got any info for what is the best order of components/tubes/bellsNwistles to install, before the engine installation, on the engine before mounted, and to the engine after mounting?
I have tried looking everywhere and most vids and threads skip through electrical harness and small external parts (heat shielding, tubes, lines, etc)
Would be super! my first engine re-build ever and trying to get it finally put together :D
Hello and welcome to MSO!
JT has a crazy build thread and details everything I would follow his order https://mazdaspeeds.org/index.php?threads/johnnytightlips-build-maximum-carnage.7025/
also lots of great how to within this section: https://mazdaspeeds.org/index.php?forums/mazdaspeed-3-how-to.109/
If not in there create you own build thread and ask the specific questions you want answers to
Edit: also this thread https://mazdaspeeds.org/index.php?threads/how-to-assemble-a-forged-motor.15530/#post-107256
  • Like
Reactions: J S
Thread viewers
