mattsark
Last night, I stopped at shell to get gas. Car was cold started and driven for about 15 mins after sitting for 8 hours and had been at operating temp for about 5 or so minutes. Filled up a full tank, next thing you know I go to start my speed and it won’t crank over, nothing. I heard the starter relay click. Had my friend bring some battery cables and we tried to jump it, still wouldn’t start. All the accessories (heat, lights) all worked but car wouldn’t crank over. I ended up having to pop the clutch and push start it. This morning it started right up just fine, went to advance auto to test the battery. Cold cranking amps were good and the battery tested good. So the battery isn’t the issue. This was after driving 5 minutes and it started fine again. I’m assuming either my starter is starting to go out or the connection to the starter is bad? Anyone ever had a similar issue with their speeds? I never heard or seen a speed owner having a starter issue at 121k miles. If you can give me any advice, experience, knowledge or help, I would greatly appreciate it. Thank you.
