Enjoying the Ups and Downs of My Speed6
070Slydinthru
Silver Member
Greetings all, I'm Steff and i live in Fairfield CA I have had my Speed6 since early 2020 I haven't done much to her yet, but since the engine failed last year it was time for a transplant so i acquired an engine from JDM engine bay and set out to swap,
all was going well with upgraded ACT clutch and Damond Motorsports MM's new coolant hoses and a set of axles . I've learned so much from the forum already and appreciate the wealth of knowledge that exists here.
When I was shopping around for a new project I almost grabbed one from that area. (was this one for sale recently?). But ended up going back to the beloved speed3. Glad you are getting her going again.
Thanks yeah its not too bad a few mis matches nothing big though, I picked it up in 2020 so not this one.
I'm in the middle of swapping the engine before it goes in ill have to address a leak from the transfer case that was not there before I pulled the motor, Ill most likely do the HPFI before it goes back on the street. Once the motors in suspension, coil overs and bushings all around and then brakes to start.
